Steering/Suspension component questions, and brake fittings and line size questions
'69FuryIIIConvertible
Fixer of junk
Newcastle, Ontario, Canada
Okay, more questions.
My inner tie-rods, Are the Left and Right thread? Or are they the same thread?
For the outers I have found MOOG part numbers ES352R and
ES355RL, are these the correct tie-rods?
I found Moog K7014 for the Idler?
and Moog K7006 for the upper control arm bushings?
Are these correct? Does anyone know the Moog number for the inner tie-rod?
What diameter of lines are there on this car? (I regret taking them off so long ago)
And what size of fittings will I need? (Master, proportioning valve, rear prop. valve, wheel cylinders, calipers, etc)
I appreciate the help.
All the brake lines are 3/16 fittings are the standard except the two at the master cyl. Tie rod ends are the same inner and outer you need two of each should be done so sleeve turns same way on both sides.
Perfect thank you! I'll pick up a roll of 3/16th's and get a few dozen fittings.
Front end and brakes are next after I finish the drivetrain............who knows, I may even get to yard drive it this year.
Nick
I appreciate the help, I really do, you guys are a huge help when I have questions. This restoration has been quite the learning experience.
