70NPORT
I mistakenly posted the beginning of this odyssey over in the "engine, transmission & drive line" forum not realizing there is an "ignition/electrical forum" as well......so..
I'm switching my 70' Newport / 383 motor from a "points" type system to an electronic "pointless" system driven by an ECU. I've got the new distributor, ECU module, and ballast resistor installed and plugged in ready to play.
The new distributor was put in place of the old one in the same exact position, that is the rotor in the new dist. is pointing in the same direction it was in the old one (I marked the position). Also, the vacuum advance can is in the same position the old one was before I pulled it. I have ea. plug wire identified with its corresponding spark plug/ cylinder (#1 cylinder, #2 cylinder, #3cylinder and so on). Chrysler firing order is 1,8,4,3,6,5,7,2 counter clock wise if I recall correctly.
The ECU is wired to the "hot" side of the new ballast resistor (via blue/yellow wire spliced into the existing ignition feed green wire which then plugs back into left side of ballast) AND to the negative side of an MSD blaster 2 coil (via a black/yellow wire). The ECU is mounted atop the wheel well with sheet metal screws w/thin rubber washers. I'm pretty sure its grounded out. I checked all connection points w/12v test light and all is energized when the key is turned to the "on" (but not "start") position, so it seems like I have electrical connectivity. So I turn the key over, the gear reduction starter spins the 383, but the motor just will not cut over into "run" mode at all.
Any ideas on what could be wrong??? Guesses? Something I have yet to think of? I did a 318 a few years ago and that went like a breeze, what' with the BB motor?
