Strange electrical gremlin
tbm3fan
Pleasant Hill, CA
I have had my car since 2009 and have never killed the battery. Well last night I was putting on the air cleaner after painting it. I opened the door for the remote hood release, closed it, turned around and then turned back when I said to myself why didn't the interior lights go on? Opened the door to check and nothing worked the battery was drained. Oh hell now I have to charge it as I thought I must have left the dome light on somehow.
So today I also stopped by the auto parts store to get some #90 bulbs for the interior courtesy lights under the dash. One had a bulb and the other didn't. So first I connected the battery to see if the lights worked and they did. Closed the door and they didn't go off. WTF? So I check all doors and the little trigger switches to make sure they were smoothly working. They were fine. Hmm? Light switch is in correct position. Well don't tell me I have to connect and disconnect the battery when running the car? What is going on?
Ok, let's just put the new bulb in on the passenger side and I do. Nice and bright. I close the door and all lights go off??? Open and close again and they go off. Now I know what happened. Over the weekend the bulb holder had been hanging since 2009. After putting the carpet back in I saw that and it reminded me to screw it into place which I did. Had no bulb so I left it. Apparently that was the source for grounding the battery. I went back in, took out the new bulb, and the lights once again wouldn't go out when the door closed. So I guess without a bulb in those sockets one has a direct way to drain their battery like I did right into the dash.
It's little things like that which drive you mad. I had something similar to that happen to me with another car I owned....kept draining the damn batt until I figured out (by accident almost) what was going on.
Gary, did you get the dimming headlights figured out yet?
No, she's sitting in the garage waiting for it. I removed the grill, bumpers and other stuff to repaint...got some argent silver from Eastwood for some of the trim work...figured since I'm there chasing down a short I might as well repaint some stuff that was getting worn out. You start out to do one thing and end up do a hundred other things on top of that.
