TF 727 Output shaft end clearance in the case need to be adusted/ shimmed?
Esslingen, Germany
Hello transmission Pro‘s,
Just putting together my 66 A727 transmission.
I’ve put in 3 new thrust washers in the Output shaft Assembly and measured clearance under the small Snape Ring on the shaft within tolerance (.016“ /0.4 mm).
Installed the output shaft assembly back into the case and there is a lot of clearance.
I can move the shaft in and out by approx. 0.1“
Is this clearance „fixed“ by the roller bearing when clamped in the housing Extension, or does this require extra shim to be placed somewhere else.
Did not found this mentioned in my Shop manual and Tom Hand book.
Don’t worry about that until the trans is completely assembled and you check input shaft endplay. The output shaft end play will not be correct until everything is assembled. If the input shaft end play is within spec then the output shaft is in spec.
Great, thank you !
