Fast Eddie B
So far so good. Idles a little high when cold. The ATII works. AC and heat. The cruise control works! I haven't had a car more than 20 years where it still worked.
The ride is incredible. Makes the worst roads in town seem like they were just repaved. It is tight and super quiet inside.
Here are the little things I found. If any thing strikes you something you have experienced, any help on solutions would be much appreciated.
- wipers not renesting all the way down.
- trunk release not opening trunk.
- funny 'hiss' seems to be coming from behind the dash, around the light switch, when it is in Drive. Not in park. Not in reverse. In Drive. I don't think it is my imagination. Sounds like a vacuum leak? No noticeable performance loss, but what would I know.
- No kick down to second gear above about 30 when you matt the accelerator.
- might need u-joints.
- passenger winder struggles to go up and needs help the last inch
- pass rear door lock doesn't unlock
- "dome" switch on rear door armrest panels does not appear to do anything.
- headliner is sagging a little in the middle
- fuel gauge pegs beyond full. Starts to move after a while. At half full reading it was about half full.
