Torque converter clearance
moparmike65
canada
When I install the converter and trans to the motor how much should I pull the converter back out of the trans towards the motor.
Thanks Mike
The better question is if the convertor went all the way into the front pump when installing.
If you have to pull it up towards the flex plate, you're good.
