Torqueflite 727 3-2 PTK
What I have done in the fairly recent past for my 1969 Chrysler 300 and & 1970 Chrysler Newport Custom 727 Torqueflites is to get a used valve body for a 1971 and later 727 from an automatic transmission rebuilder supply house (this will not necessarily work for earlier torqueflites with the cable shifters of course so check interchangeability with the supply house on your application if you have other than the model years I have done this with). Valve bodies really do not wear out and they usually have the 71 & up PTK ones available for pretty cheap prices. In the past, I have paid around $50 for one. You might want to familiarize yourself with the difference in appearance of the PTK valve bodies compared to the 70 and earlier ones to ensue you are getting the correct one - the PTK ones have and added housing with spool valves in it that do not exist on the non- PTK one. You might try searching for these suppliers locally and get in touch with them. They usually do high volume business with transmission shops and so their prices are pretty cheap and I haven't had to be a business to buy from them. These later valve bodies make a very positive difference in the responsiveness of the transmission and really enhance overall performance. Good luck.
I believe there are a couple tranny shops in my area (rebuild/sell parts) I may be able to hit up, thanks much. BTW: Just for information sake what's the difference between the 69' 727 living behind a 383 and the 70'?
So this took a while to sink in, but you're saying to buy the used valve body rather than the PTK part, and swap the whole valve body?
I do not know of any difference between the two model years, so that is why I suspect the application range of the part you were considering buying may not be correct, or there is some nuance I am not aware of that was bypassed when just substituting the 1969 valve body with PTK one. There is another option for you on this ebay auction, which says the modification applies to 1967 to 1970, but I do not know whether that really means to or through 1970. You might want to consider contacting the shop for clarification.
http://www.ebay.com/itm/Torqueflite...cessory-Simple-V-Body-Type-1967-/221484557427
The only thing I note in the description of the above add on part is that it does the kickdown at 3/4 to 7/8 throttle, whereas when using the used stock 1971 and up PTK valve body, my cars do the part throttle downshift at significantly less throttle movement.
Steve
Yes, you now have it right. There is really no savings in time to install either the add on part or swapping the whole valve body.
