BigBlockJoe
Hello to all Car Friends,
I am a newby member from Hamburg Germany. I am a owner of a 1978 Chrysler Newport with a 400 cui engine. And this is my very first post.
First I want to thank a lot of different People. I gathered a lot of different valueable informations for my Projects.
Now a description of my little "Problem"
In the last two month i spend a lot of time with a tiny caburetor repair. At the end it was a total let me say "Chrysler Lean Burn Carnage / removement "
This is what i swapped / changed:
1.) New 1905 Edelbrock Q-Jet
2.) New Mopar ECU ( the orange box ) with a new distribtor with vacuum advance
3.) New Edelbrock Air Cleaner
4.) A new high energy MSD Blaster2
5.) 8 new spark cables and plugs
6.) New Breather
7.) PCV Valve to air cleaner ( not to the edelbrock PCV port )
8.) New Voltage Regulator
9.) All hoses has been renewed
10.) All vaccum plugs has been renewed
11.) The Kickdown linkage hast been checked and reset to factory values.
12.) All fluid Levels are within specifications
Additional to this i gave the car to a Special Garage in Germany. The carburetor was calibrated, The ignition Timing was set to 14 degrees btdc Initial. The Intake manifold has been resealed ( no air leaks at all )
Now everything seems to be fine. the car is starting just second after cranking. The car is idling very smooth. The accerleration from the traffic light ist good ( for a 2 ton car ). No hestitations / No backfires etc. The tranny is shifting very smooth without runaways or other Problems. the car shifts good. The Engagement is very smooth.
But if i push the pedal to the metal ( Kickdown 3rd to 1st gear, the accerleration is very poor. It feels like the car is connected to a big rubberband. But when i release the throttle for a quick Moment and push the pedal again the car is accerlerating fine. It seems to be that this Problem just happens when i push the pedal 100 percent ( the tiny kickdown Switch / resitance in the pedal )
I am running out of ideas.
:70s_rule:
Can anybody enlight me what the Problem could be.
Thanks i advance
Markus
6.) New Breather
:70s_rule:
Thanks i advance
Markus
