Dodge97318j
So I drove about 100 miles before the transmission started giving a flare shift. And then the upper radiator hose sprung a leak. And that's when I found it. Transmission fluid in the radiator, and coolant in the transmission.
I've opted to bypass the radiator cooler with an external cooler. I tried to drain and flush the transmission a few times, installing a new filter once but realizing quickly the damage is done. Clutch material plugged the filter.
So I know what I need to do. My question is, are there any converters and overhaul kits anyone here has had good or bad luck with?
I have taken the transmission apart completely and found all the hard parts and bushings are in great shape. I know that I will never get the converter flushed, so I need that and probably just a basic overhaul kit with clutches, steels and seal. The bands both look ok and aren't missing any material. I want to do it once and the right way but the cheapest way possible also. Please let me know your thought.
