C Sickness
That connects my instrument panel to the rear body lighting harness. 1970 300.
There's a 6 cavity plug that carries the rear tail/stop/marker/ back up lights. The manual shows a drawing of the instrument panel end. There is no drawing of the body harness, only a schematic. Next to the plug is a pair for the driver's door pin switch. Under dash is busy with harnesses and air conditioning ducts, can't see much.
I'm guessing the harness runs somehow along the driver door sill, and back to the trunk. Hoping the plug could be behind the kick panel, or under carpet, and not up behind the duct work? One conductor, (black), for the running lights is open, and i suspect it's pulled from the cavity, or the 6 pin is only "half way" plugged in.
Has anyone noticed this, after pulling the carpet and kick panel?
