Upolstery material
monaco
ontario
Can anybody tell me where to get upolstery and tools? I can't find repro or nos seat covers for my 66 monaco so I'm gonna give it a shot and try and do it myself
SMS of Portland for the material. Describe it to them and/or send a sample. It may take two months to get a response.
You are going to need a walking foot sewing machine to start. Older ones are the ones to get and they aren't cheap. Buy some books on the subject to start with.
If you are really serious, these guys have the materials. Upholstery Fabric, Wholesale and Discount Auto, Marine, and Furniture Upholstery Fabrics
I did my 53 Windsor with covers from these guys. If they have the patterns, they can do it. It won't be factory like Legendary or SMS, but they do nice work. Automotive Interiors & Accessories for cars, trucks, vans, & suvs
Mine was custom with tweed and vinyl. Fit was perfect.
SMS for original material. Expect $100 per yard for fabric and $55 or so for vinyl from them. There are cheaper materials out there if you aren't worried about having original material/pattern.
Chrysler fabrics had a metallic tint to them and the vinyls had a pearl tine to them, even white vinyl. You don't realize that until you put a non-Chrysler fabric/vinyl against the factory items.
Legendary might have the front bucket seat foam, if needed, as it's the same for Chryslers, Dodges, and Plymouth C-body cars back then. Getting ready-made kits in OEM fabrics might be a trick. Look in the Legendary catalog, even online, and see if you can find something similar in seat configuration and body series. IF you find something similar to what you have, you might contact Legendary to see if they can use those basic patterns and build something with OEM fabric/vinyl for you.
The deal with upholstery is that you have to get it pulled tight on the foam/seat base build-up to get rid of wrinkles and loose spots. Not quite like hemming a cuff on Dockers or jeans.
Getting the correct machinery to sew everything together is important, as it having a large work table to lay everything out on, mark the patterns, and other seams. Quite a bit of labor involved in doing these things! Not to mention experience in how to use the machines and such. Not to say that somebody who hasn't done it before can't do it, but just be aware of how much time and labor CAN be involved. If there is a community college with an upholstery course you can take, taking it might be a good thing to do BEFORE you venture off into your possible project.
As for a local upholstery shop? Check with new car dealers and see where they might get their warranty upholstery work done. Used car lots, respectfully, usually just want something "covered" and little else, which is much less than what's expected by a new car customer who desires the repairs to be "as factory".
The upholstery shops who have done dealership work will have fabric/vinyl catalogs for the OEM fabrics and can probably order them for you. Probably from their supply network which might end up being from SMS, by the time it's over. BUT they would know how much to order, to start with, which can be important.
Might some of the slip covers at Walmart (or similar) work?
SMS Auto fabrics. Good chance they will have the exact material for your car. Give them your info and they will send samples. If the original material is important to you they will probably be able to help you out. Prepare for sticker shock though!
