Valve spring shim ID too large..problems?
zep058
Engine guys…I’m shimming my valve springs to attain a set installed height as part of a Lunati cam upgrade which was progressing fine for a second..
My question is..the ID of the shim is slightly larger than the valve guide boss/seat by about 30 thou. 1.500” OD. Should be 1.000” ID is needed but most available are 1.031” ID.
If I was to keep the larger ID would there be any chance the lower part of the spring “walking” side to side with shim not located on the boss. I’ll have 120lb seat and 330lb open load on those shims, would that be enough to “hold” everything in place.
It’s a street cruiser, not strip powerhouse. 383/516 heads.
I’ve had real difficulty finding a supplier for 1,000” ID shims locally downunder strangely. Cheers
Should not be any lateral motion of the shims as the spring opens and closes. If there was, the head-side of the valve spring would show movement, too?
