Vent Window Adjustment
Mopar_Mudder
Wisconsin
1962 Crown 4 Door
Is there anyway to adjust the hinge on the vent window? Sure doesn't seem like you can.
The glass on the vent window sits too far back at the hinge and above it. Glass does not seal on the front edge, and the back edge is actually hitting the division bar frame when you close it.
I took it totally apart because it moved so hard you could barely open it, never paid attention to how the glass fit before hand. Got the pivot and latched all cleaned up and working good. Also replaced the glass setting rubber on the bottom because it was rock hard and the glass fell out of it.
In my experience the frame is made in a set position and the glass can only be slid back and forth in the channel of the lower pivot. You may be able to bend the lower pivot in the frame by using the glass and channel to bend it, but that’s about it. That’s my experience others may know more than me.
