I've plugged an inexpensive volt meter into the cigarette lighter in my 71 Fury. The battery, after sitting all night, is usually between 12.6 and 12.7 during the warmer months of the year. When the car is running shortly after start up I see voltage around 14.9 with brief spells at 15 or even 15.1. As the car warms up the volts will gradually settle down to between 14.5 and 14.7 with the brake lights on. When the brake pedal is released the voltage will often return to 14.9. I rarely drive with the lights or A/C on and don't use the heater much although everything works fine. I have done the under hood ammeter bypass mod and have done my best to keep all accessible connections clean. The battery seems good with no noticeable loss of electrolite. I checked the voltmeter in my newer daily driver and it's always steady at 13.9v. My question is, do I consider replacing the voltage regulator in the Fury? Is it overcharging? Thanks in advance for any advice.
