ideologist
I'm thinking my regulator crapped out, does anyone know which replacement part is correct? I see NOS units for $180 but I'm not paying that. I have a 65 NYer
Get one from @FURYGT . They look close to the OEM, or at least like the replacement aftermarket units that you would have bought when the car was new, but they have the electronic internals.
I don’t think @FURYGT sells them, but will defer. If someone can chime in on a solid state instrument panel regulator, please do as I will likely procure several for 4 or 5 for the vehicles in my fleet.Id like to hijack this thread.....as its related. I bought the VR from furygt and have been very happy with it. I also replaced the dash VR with the solid state one. Cant remember but it might have come from him too. I am still seeing my interior and dash lights increase brightness with RPM though. Thoughts? ammeter increases with rpm too. idle is just below center, 2k is about +1/4
1.With your headlights on??Id like to hijack this thread.....as its related. I bought the VR from furygt and have been very happy with it. I also replaced the dash VR with the solid state one. Cant remember but it might have come from him too. I am still seeing my interior and dash lights increase brightness with RPM though. Thoughts? ammeter increases with rpm too. idle is just below center, 2k is about +1/4
The voltage limiter for the panel is either inside the fuel gauge or mounted on the back of the panel--depending on which model of C you have..Where is the instrument panel VR? How is the affected if you want to swap to LEDs? My nighttime visibility sucks
Headlights off. Headlights are on their own harness now too..never bypassed the ammeter.1.With your headlights on??
2.Did you do the ammeter bypass under the hood yet??
You have GOT to bypass the ammeter.never bypassed the ammeter
Run a wire from the battery stud back of alternator 7/16 nut. Use 10 gauge and connect it to a 14 gauge fusible link and bolt it to the battery stud of starter relay 1/2 inch nut.
Done.
This will save your car!!
I have heard of it but do not understand the point of removing the ammeter from the loop. I removed the headlights from the in car harness cutting out a large portion of the power running through it. I kinda like having it doing it's job....You have GOT to bypass the ammeter.
Done.
The theory is that the ammeter can't handle the current that passes through it. IMHO, the problem is blown way out of proportion.I have heard of it but do not understand the point of removing the ammeter from the loop. I removed the headlights from the in car harness cutting out a large portion of the power running through it. I kinda like having it doing it's job....
Since you've cut the amount of current dramatically with taking the headlights out of the loop (I assume a relay system), I don't think that you need to do the bypass.
