twostick
Does anybody know if the rear doors of a 65 Polara wagon are the same as sedan doors?
Kevin
Kevin
Now . . . IF you have some decent fab skills, the bottom part of the door could well be the same as the 4-drs, but the top part of the door is where the difference will be. THAT part of the door is spot-welded to the bottom part of the door shell AND could be swapped out, then re-welded to the door structure, plus changing out the glass/regulator assy.That would be my luck...
Kevin
Thanks.Now . . . IF you have some decent fab skills, the bottom part of the door could well be the same as the 4-drs, but the top part of the door is where the difference will be. THAT part of the door is spot-welded to the bottom part of the door shell AND could be swapped out, then re-welded to the door structure, plus changing out the glass/regulator assy.
Remember, too, that all C-body station wagons are on a 122" wheelbase, same as the normal Dodge C-body cars of that time. Plymouth was shorter and Chrysler was longer, in the wheelbase area.
See if you can find a salvage yard with a Hollander Interchange Manual for your model year. That should tell you what fits or what CAN fit (with a few mods).
