Wanted: 1968 Polara Lower Control Arms
Kooka
Howell MI
Does anyone have a decent pair of RH and LH lower control arms for sale? We removed those on my wagon to add the Firm Feel stiffener plates and poly bushings and found metal to metal wear on the big end thru holes on both so the holes are now partially oval. I need to start with something better. Please let me know if you have something. Thanks.
I believe they used the same lower control arm on all C-bodies, with imperial being a possible exception?, from about 65-73.
you need to post a pic of what you are referring to....
There is a "hole" that looks like half a hole that is for the torsion bar adjuster block...
