Take a picture.Ah! Great!
The power antenna works so i guess they got power from somewhere else.
Does anyone more than me having a dual headlight relay installed? Its a square box installed next to the radiator.
Is this just the have all four as headlight (high beam)?
Then I need one for my house - doorbell keeps failing!Looks like an old doorbell transformer...
That is a headlight relay. Not a factory one though. Take the cover off and you'll see two relays, one for low and one for the high beams.
There was no headlight relay, except for the one that opens and closes the headlight doors.but why did they use it? i guess the factory relay are broken back in the days mabey?
they have cut one of my red cable going to the headlight and going in to this instead
There are a couple reasons for installing a headlight relay.aha ok, so they use of it is to???
im sorry if im not getting it
I will do that. I'm doing a power window relay for my car right now.Hail to Big John, Lord of all things electrical! Any chance you could show us mere mortals how to wire a relay into the headlight circuit? I'd like to add one to the vert.
That's absolutely correct. It's a pretty simple circuit and the results are worth the effort.That was quite easy even for a novice electrician like me. I started from scratch rather than buying a pre-made harness to do it. I wanted the experience of doing it myself. Put relays on the Polara, Park Lane, and F100. No hurry for the other two Pony cars and besides tighter compartments mean I need to look around.
