AFTERMARKET REPLACEMENT RADIATOR SUGGESTIONS
HOT FURY
ARIZONA
I am a the point of looking for a radiator upgrade for my 66 sport fury to hopefully help with cooling for the 470 stroker being built. I want to try to go with something that will either accept my factory shroud or has a shroud to pull air properly through the radiator at slow speed or stopped. I will be using a clutch type fan like whats on the motor coming out and would prefer not to use electric fans. Cold case has one that looks like it may work and accommodate my factory shroud too, the link below shows it. Any suggestions from anyone who has replaced theirs? I currently have the 26" OE one.
66-70 Mopar C-Body 26x17.5 Aluminum Performance Radiator
If you're not in a hurry watch Holley's clearance sales. I got a great deal on one for my charger I'm going to try this spring
