- Joined
- Nov 12, 2010
- Messages
- 2,736
- Reaction score
- 2,413
Link: https://www.facebook.com/marketplace/item/188431010813517/-1958-Plymouth-Savoy
Seller's Description:
1958 Plymouth Savoy 4-door Sedan
Pros: Runs/drives/stops well. Reliable. Nice interior. Brakes have been gone through and converted to dual circuit. Recent carburetor, full tune up, electronic ignition conversion, 180F thermostat, and valve adjustment. New voltage regulator. Just replaced upper control arm bushings and idler arm bushings. Oil, filter and ATF are fresh. Tires are newer bias plys. Lights, signals, dashlights, heat, wipers, horns, gauges, speedo all working great.
Cons: Alignment isn’t perfect. Tires could use a balance. Radio inop. Exhaust is an amateur job. There’s a little filler in the rear wheel arches just forward of the wheels, and a few pin holes in the passenger side rocker panel. Paint is older and not quite as nice as it looks in the pics. Driver’s seat cushion is a little sagged. $13,300 obo - no trades please.
- Driven 77,000 miles
- Automatic transmission
- Exterior color: Blue · Interior color: Blue
- Clean title
- This vehicle has no significant damage or problems
- Last 2 pics are inside the top of the front fenders
