Gerald Morris
Surprising it lasted so long.Just dropping this here for posterity.
1965 Chrysler 300 4dr hardtop 383 Auto
My fuel gauge suddenly is on the fritz this spring. Has worked as it should for the lifetime of the car.
Nope. When they go, they usually go out all the way. Either the float fills up, or the crude potentiometer windings in the sender finally break with age and poccasional moisture corrosion. The little wiper from the float arm might also break. Anything except the float warrants full replacement. I've been reasonably lucky with the sino-repops, having bought two, both of which work, amazingly enough.Occasionally now when I start the car (or turn the key into accessory) the fuel gauge does not move... or moves after some time (*several minutes) of the car being started, but very slowly. Sometimes it works fine... sometimes nothing.
I ran a ground wire from the battery to the sending unit praying that was the issue. Turned the key on, no movement in the gauge. Damn. Not the sending unit.
Am fearing it is the Voltage Limiter/Regulator... ....
Really trivial bro. You can either replace it with a true OEM sort for anything from $15-500, depending on the vendor, or get a solid state one made to fit the instrument panel for ~ $55, OR, get a good generic 12VDC=>5VDC convertor, and then wire it into your old stuff. I did that for a little while, with some so-so results from the old sending unit, then got a NEW sending unit and new Autogage fuel gauge wired for 12 VDC which works beautifully. Then our '66 got wrecked. Still have the fuel gauge and am using the new sender in our '68 w the original instrument panel stuff, for the present. The stuff yields fairly accurate data. as far as I can tell when pumping petrol.
Think this is what has happened as I was driving the other day and Fuel gauge was not working and then ALTERNATOR gauge pegged hard to the top... and let out a big puff of white smoke... and now it dead in the water. Literally tinted the actual gauge glass with smoke from the inside too. The Fuel gauge also stopped working. Lame.
DANGEROUS! For NOW, lug together the red and black leads to that old ammeter, bypassing it. The best place for this is on either of the terminal studs which the leads were attached to. Just make SURE you pick just ONE. Those old ammeters can burn up your car man. Add a 3rd wire to the stud, and feed that to an after market VOLTAGE meter. This will give you a fair idea of how your alternator is charging. Look up the MAD bypass if you like, for more information.
If you don't lug off that shorted out ammeter, you won't have to worry about any instruments soon. Be sure and do this ASAP. Its a SERIOUS hazard.So the whole cluster will have to come out. Terrifying. Think I will just live with it for now. Nothing like having NO fuel reading.
**UPDATE
Oddly, I went for a drive last night and the Fuel gauge came on after driving for a while, so it is not totally dead. Just working when it wants. Fingers crossed it doesn't go up in smoke too.
It will with the rest of your instrument panel if you don't get RID of that bad ammeter connection.
