moper
- Joined
- Nov 15, 2010
- Messages
- 814
- Reaction score
- 448
It's unfortunate, but I don't see it as a production part problem. You experienced a failure and that happens especially in 650 miles with racing. Personally I'm not a fan of hydraulic rollers. My feeling is they are a means to no real end because you have to run a heavier spring to control them, but the lifter collapses with too much spring. It's a tight tolerance to maintain in an environment where high rpm shifts are common. Solid rollers have a place in the world because you can run any spring and the lifters are lighter anyway. Hydraulics, unless the engine is a very mild deal, simply are too heavy and unable to deal with real springs. As a "maybe" I would test your valve springs. If they are weak, you may have had harmonics that helped the lifter fail. If you find other lifters with "loose" tie bars that may be the case.
