Heaterbox restoration
Clarion PA
I’m about to take on the task of rebuilding the auto-temp ii heater box in my 72 imperial and I was just wondering if anyone had any diagrams or tips about the process.
Thanks!
-Josh
What concerns are you wishing to address? New evaporator core in your stock? New heater core in your stock? Failed actuators? New blower motor? Applicable gaskets and seals?
One thing I have noticed on our Chryslers is that the vac hoses to the actuators and such appear to be a high-silicone content rubber hose. Definitely NOT what's normally available for vac hose. Plus there are color codes on them, too! So do NOT dispose of them.
Just curious,
Just curious,
The main thing is going to be the heater core. But I figured while I have it out I might as well go over it and check everything else out and clean it up.
I recently rebuilt my non-AC heater box and it wasn't too bad of a project. I would check for cracks around where the vac. actuators are riveted to the box. I repaired the cracks with fiberglass epoxy resin. Definitely recommend the gasket set from detroit muscle as posted by @3C's & a D?
I had some rust on some of the components from the old core leaking inside the box. I used por15 and it worked very well.
Their was a rubber hose that I believe is used to feed air to cool the mouse cage motor, that was brittle and cracked. I was able to repair it but it may need replacing depending on the condition of it.
Careful with the vent duct work and plastic vents themselves. Especially if you have one that connects to the side near the a-pillar, which draws fresh air in. I had to replace that ducting and it was a bit of a pain to find one on ebay.
Pay close attention to where the vac lines are routed and what color code connects to what actuator. Mine wasn't connected when I bought the car and it was a bit of a puzzle putting it back together and making sure the switches opened the right vents.
Another challenge I had was the cable that connects the dash lever to the heater box. Mine was badly bent and was binding terribly when trying to move the heat control. I was able to bend it back and get it adjusted properly it was just a pain getting it reattached.
Take your time, take more pictures than you think you need and see if you can get a manual downloaded or buy a paper one, super helpful to have a diagram of what it should look like, especially if someone else before you "knew better" and fudged it up. :thumbsup:
A good radiator shop can pressure test and or repair your heater core if needed.
