Lower Windshield Trim Removal 65 Fury
65Fury440
West Central FL
Can anyone tell me how this trim comes off?
I have tried fishing around between the rubber gasket and trim but can't hook any clips.
Newer models have vertical clips pointing upwards you just kind of pry away from the cowl, it seems like maybe this uses clips horizontally?
Screws, one on each end inside the door frame, vertical spring clips across the center - same type as used on door panels.
