commando1
Correct model fire extinguisher and bracket...
Unbelievable
Unbelievable
Unbelievable
I meant that as high praise, btw.Correct model fire extinguisher and bracket...
Unbelievable
I thought I included this picture in my previous update but i guess I forgot.
The CHP use this tubing to run wire through, three different sizes were acquired and the correct size clamps. The clams were installed in the original holes drilled by the CHP. The CHP used sheet metal screws in most locations but the far clamp couldn't be put in with a sheet metal screw so a machine screw was used. This screw is seen in a vintage photo and a on the salvage harness we were lucky enough to find, oh, I had to track down a slotted round head screw, thank god for McMaster Carr.
Alan
Another distinguished member of the OCD Fraternity.
Welcome... Nice plane.
When I was doing the torpedo bomber I was lucky to find someone in Los Angeles who had all new molded canopy pieces for the plane. That is a lot of pieces when you include the machine gun turret. While in the final stages I allowed the fellow in charge of overall plane restoration, me being the TBM3E plane captain, to take the pieces to someone who could fit them into the various frames. Imagine my horror when they came back using steel phillips head screws. The originals were aluminum slots. Took me several months to go through the plane removing each and every screw to be replaced by the correct slot screw, washer and lock nut on the backside. Had to be around 1000. Thank god for the aircraft supply store opposite Oakland Airport. Same goes for the ship. I have a large supply of 6-32, 8-32 and 10-24 slotted brass screws to replace all the phillips head screws I run across due to sloppy sailors using whatever they had when they lost the original or damaged it beyond belief. It truly is the smallest details which set a restoration apart.
Steel being mounted to aluminum is unavoidable in some instances, there are many parts where steel is used such as undercarriage mounts in the old aircraft or the engine mounts etc.IDK much about planes... isn't it improper to use steel with aluminum? I have dealt with a number of small aircraft guys and have always been impressed by the work effort that goes into the reskinning and wing replacements... but I thought there were a lot of rules about dissimilar metals and corrosion inspection.
To be a restoration craftsman such as yourself requires an attention to detail most are unwilling or unable to provide. I have an immense dislike of the better than original crowd who want to line up screw heads or mount tires with a certain letter at the valve stem... but somebody who wants to make it correct and authentic is a special person IMO.
Isn't this the phenomenon of where the steel forms a ferrous oxide type of surface plating thact actually protects itself.SO in fresh water the steel will rust bad, but in salt water it wont when it proximity to aluminum.
In the 70's it was fashionable to design steel buildings that actually turned to a rusty red.
300rag is right, Depending on the way the electron flow went via salt or fresh water, one or the other meal would corrode thus preserving the other. Years ago Mercedes Benz used to put zinc blocks in the chassis of their cars that would corrode away over the years and save the steel bodywork from corroding. I am not sure if they still do it or not.Isn't this the phenomenon of where the steel forms a ferrous oxide type of surface plating thact actually protects itself.
That's interesting, isn't it curious that they would develop a particular type of steel to rust up to self protect?
The reason I remembered about that was I was taking metallurgy in college and at the time a building using that steel was going up. Very radical for the time. The professor stole some material off the site and had us analyze it.
In fact, here is the building.
