As was mentiined - the bore size is almost irrelevant for what you want to do. Thinner cylinder walls means lost ring seal and lost power. I would leave the bores at the smallest size that allows you to achieve a straight, round bore with the right finish for the rings being used. Instead, have the crankshaft offset ground to increase the stroke. You should be able to turn the journals down .020 and get .040 more stroke (you end with 3.35) which will give more torque straight off idle. It's not a massive amount, but more power of the kind you need in that car. It will also give any piston more static compression in your block, adding to output. That's what I'd do.
