polara383500
Looking for roller rockers. Was wondering which one I could get without doing any grinding on stock iron heads? if changing them do you have to change the push rods to longer or shorter?
Full roller.Will these be "full roller" or just "roller tip"?
Full roller.
No street!440 source make some that are affordable. But the needle bearing sizing is questionable.
Is this for a serious race application?
Just looking for 1.5 rockers doesn’t have to be rollersGotta ask - why roller? I have run them all. On the street for a mildish car I use Crane iron. My 69 GTX build has Harlan roller rockers but it makes 713 hp/707 torque and has mechanical roller cam so reliability ain't great anyway.
Factory stamped steel are designed to be 1.5 ,although some sources claim they may be a hair shy.Just looking for 1.5 rockers doesn’t have to be rollers
Just looking for a lil performance. LolFactory stamped steel are designed to be 1.5 ,although some sources claim they may be a hair shy.
Are you looking for performance gain?
You won't find it here.
Adjustable rockers are a step up from stamped rockers in that you can get the lash correct. There is some (and I mean only some) gain from that.Factory stamped steel are designed to be 1.5 ,although some sources claim they may be a hair shy.
