A quick question for you mopar experts out there . When placing a 1406 eddy on a stock 71 New Yorker 440 do I require the adapter? A few years back I put a 1406 on a 74 Road Runner which had the 360 and the adapter was required I believe the 360 had a carter carb but i am not 100% sure the 440 has the Carter so I am thinking that the adapter is required plus the throttle linkage adapters any other tips when changing over to an eddy what about the cruise control? Will I be able to take the piece of the Carter throttle linkage and transver it onto the eddy. .any suggestions would be appreciated. .thanks guys
