15x7 magnum 500 wheels trim rings
Mohawkmike
NH
I have a set of 15"x7" either mopar road wheels or ford magnum 500 wheels my question is how deep are the correct trim beauty rings 2 1/2" or 3" deep
Chrysler did not use 15" Magnum 500 wheels in OEM production. All of the Ford Boss Mustang 15" Magnum 500s wheels did not use trim rings, as they were solid chrome as the earlier Chrysler Magnums were.
The Chrysler 1970+ W23 16-Slot and Rallye wheels did use trim rings. All 15" wheels. The width of the trim ring was varied with the rim width. Some of the OEM Rallye trim rings had a "brushed" surface as others had a smooth chrome surface.
What do the backside of the trim rings look like? This view can also determine if the rings are OEM or aftermarket.
Thanks for the response
It does not have trim rings I want to buy some because the wheels are rusty and want to cover the rust up the centers are fine just wanted to know how deep could I go with the trim rings he wheels are 15x7
To the OP, you might look at the CONTOURS of the 15x7 wheels you have to compare them to a normal 15x7 steel wheel (which takes wheel covers or trim rings) to see if the shapes/angles are the same. A variable situation, to me.
This would be my concern also. Amazon has a good no hassle return policy.
99% of the time that is true. If it's from Amazon it's 100%, but if it's from a vendor selling through Amazon, there may be some issues with returns.
I had to return a laptop I bought on Amazon that wasn't what they said it was.... That went back to a vendor that charged me a return fee. Amazon was no help, but since I paid with a credit card, I disputed the charge and got my $60 back.
That said, I still buy a ton of stuff from them and have had to return a few things that went really easy.
Good point. That being said, the Speedway style trim ring can be purchased individually to minimize the risk.
