- Joined
- Nov 12, 2010
- Messages
- 2,709
- Reaction score
- 2,387
For sale on Craigslist: 1955 Chrysler Windsor Deluxe Nassau 2-door Hardtop in San Luis Obispo, CA - $13,600 - Call Glenn: 805 431 53 seven seven
Link: 1955 chrysler windsor for sale by owner - San Luis Obispo, CA - craigslist
Seller's Description:
I’m offering this classic for inspection by appointment only. The perspective buyer must call the number provided to set up an appointment. I’m not going to respond to text or email messages. I’m very willing to make myself available for inspection at most required times. Asking $13,600. Thanks Again for checking out this add, Glenn
- condition: good
- cylinders: 8 cylinders
- transmission: automatic
- odometer: 31,241
- paint color: custom
- title status: clean
- It’s a 1955 Chrysler Windsor Deluxe two door hardtop Nassau model painted in Gold Nugget with a Desert Sand top. The paint is in good condition and still holds a shine when buffed. Also the chrome polishes out with a small amount of pitting in areas. I’ve put used replacement tires on and have all the wheels freed up and rolling. The sixty eight year old brake system will need attention but still seem to stop the car when pushed.
- The interior upholstery is in great shape as witnessed by the pictures. There are no cracks in the dash pad, door panels or rear side panels. The rear seat even still has the clear plastic protective covers on it. The painted dash is beautiful and no signs of fading. The original steering wheel is in great condition and will clean up almost like new. The original floor mats are still in the car and in good shape. All the glass is intact and also in good condition. The only two ares of the interior that need to be addressed are the bottom of the drivers front seat because the fabric has deteriorated. The headliner is stained with a small hole above the passenger sun visor.
- This 1955 model has the original 301ci POLY SPITFIRE V8. It’s a great lookin motor with an original air gap intake and Spitfire valve covers. Chrysler designed the so called Poly heads in the development of the first early 331ci HEMI. We have started inspecting the condition of the motor. So we pulled the spark plugs and to our surprise they look almost new as shown by the provided picture. We removed the distributor cap to replace the points and condenser but they also look new. Then we looked at the condition of the oil and it’s not at all blacked and still seems to be in good enough shape to start the motor before changing. We bought a new battery and the motor turns over very easily but the starter solenoid stuck so we pulled the starter. After this inspection of the motor we are convinced that it is in good shape and with a little attention should run.
