SOLD 1965 Fury Trunk lock assy. w/key
FFGREG
LaCrosse, WI.
I lost my key for my 65 Sport Fury and the trunk lock assembly is broken. I need the lock assembly and the correct working key for it. My mechanic has the car now and i would appreciate your reply as soon as possible. Thanks, in advance Greg located in western Wi.
You can open your trunk from the inside by removing the back seat and crawling through. Or call a locksmith to pick it ($$).
Once open, you can remove the lock cylinder and take it to a competant locksmith and they'll be able to cut you a key that fits.
Alternatively, if you know your glove box and trunk keys were the same, take the glove box lock in and do the same thing.
Thanks, I will follow up on this.
