Here's a couple new pics, the outer belt seal and looking for 2 window guides, about 19" long eachI will check my samples when I go to shop tomorrow
How much for the channels ? You need to know length? I'll probably just make the belt weather strip, thanksI have the channels, but do not have a pattern for c body belt lines. Looking at photos I have the raw material so when you remove yours send and I will duplicate. Thx
The belt weatherstrips are just folded rubber material, should be fairly easy to duplicate. I'd normally do something like that, but I'm hoping to be together and running this weekend, first time it will be on the road since late 70s. I do have the belt weatherstrips if anyone wants to see itIf you were to provide him with yours as a template, I bet there's at least a dozen of us that would buy the kit, and (while I don't want to put words in his mouth), because you provided him with the originals, you might get your set free or with a major discount.
They would fit 65-68 C body wagons. There's at least 5 parts to the kit - just off the top of my head there'd be a perimeter seal (likely with molded ends), side fillers, channel runs, and glass strips both sides.
I'd buy a set for sure!
Qqe, hopefully you read this today, I'd like to get a price and shipped today on the run channels if poss, thanks! My mailbox should be openHow much for the channels ? You need to know length? I'll probably just make the belt weather strip, thanks
I would also be on that list.If you were to provide him with yours as a template, I bet there's at least a dozen of us that would buy the kit, and (while I don't want to put words in his mouth), because you provided him with the originals, you might get your set free or with a major discount.
18" 5/8 each. I'd take a 8 ft stick. Can I call /email to order?How long are the pieces. An 8 foot section is $20.
Left you a message with my email and phone #. Accidentally gave you my "for b bodies" handle lol 65 new Yorker wagon814-509-6410
Hello, did you get a chance to ship the runs yet?I can supply you window channels also. Dave
@QQE does have a digital catalog available, (or did recently), that you can request via email.Thanks, I know that "Gary Goers" did have a good catalogue but I can not find it, even under Quirey Quality. As for the tail gate seals, what is left on mine all look like they have been replaced or are missing altogether. Is the outer belt seal and the perimeter seal metioned in this thread the same seal which is attached to the body and seals the lower portion and sides when the door is closed. What did the original look like, was it a two piece ( upper & lower) or several sections ( upper side, corner, middle , lower).
