I'm the one probably mixed up. I was talking about the 66.
No it was confusing because I guess I hacked the thread from the OP and made it with my car. Sorry OP!
So other than the cable attached to the dash control, the valve is independent of the heater assembly?No no no no no.
69+ had heater valves mounted on the inner fender.
Pre-69 had heater valves nounted on the lower passenger side of the firewall.
It was controlled by a cable from the dash control that ran to a lever on top of the heater box and then to the heater valve.
The heater valve functioned mostly as an On/Off valve and the lever on top of the heater box that moved a door that modulated the heat.
Running the cable directly from the temperature control lever on the dash directly to the heater valve under the hood still allowed you to modulate the amount of heat?I used one out of a 67 Chrysler I think, and it's worked perfectly.
Thanks for that but mine is vacuum operated. I have no linkage and it is supposed to be under the hood on the passenger fender well. If you look at my pic next to the manual valve is a plugged vacuum line. That is what controls it.
There's also the capillary tube that runs into the bottom of the heater box as a temp sensor, otherwise the valve is stand alone.So other than the cable attached to the dash control, the valve is independent of the heater assembly?
Yes. That's what I was thinking about when he said he replaced the original heater valve with one from a mid-70s Dodge pickup.There's also the capillary tube that runs into the bottom of the heater box as a temp sensor, otherwise the valve is stand alone.
I've asked myself that a 1,001 times.why in the world would Chrysler engineer a drippy, leaky valve INSIDE the firewall, only to go right back OUTSIDE the firewall again???
It has been my understanding that automotive engineers need to produce new/redesigns on a regular basis to justify their existence... and sometimes the bad ideas get approved for production.why in the world would Chrysler engineer a drippy, leaky valve INSIDE the firewall, only to go right back OUTSIDE the firewall again???
