Just posting this for our European friends:
Rymax Atexio +4 ATF is a fully synthetic automatic transmission fluid (ATF) and particularly recommended for Chrysler automatic transmissions. This product is also suitable for power steering systems and hydraulic systems, where an excellent low temperature fluidity is required.
This ATF meets the +4 ATF (MS-9602) service fill specification and replaces ATF+3 (MS-7176). Rymax Atexio +4 ATF is especially recommended for top-up or re-fill after repair or revision of Chrysler automatic transmissions where an ATF +3 and ATF +4 are prescribed.
Rymax Atexio +4 ATF is a fully synthetic automatic transmission fluid (ATF) and particularly recommended for Chrysler automatic transmissions. This…
rymax-lubricants.com
There's a listing for what countries you can find this oil. In Europe, Germany is apparently not on the list, but Finland, Sweden, Norway, France and Switzerland is.
Actual Mopar ATF+4 in Germany can be found here:
Recommended for Chrysler, Dodge and Jeep automatic transmissions For certain manuals transmissions and power steering systems recommended Compatible with ATF+, ATF+2, ATF+3 spezifictions
ato24.de
From that site:
Backwards compatible with ATF+, ATF+2 and ATF+3
Mopar ATF+4 is the successor to the previous products ATF+, ATF+2 and ATF+3, which are no longer available as OEM products, as ATF +4 automatic transmission fluid is fully backwards compatible. Development work by major automakers on automatic transmission fluid picked up steadily in the 1980s after initial efforts that can be traced back to the 1940s. In addition to products from Ford, GM and Toyota, Chrysler introduced "ATF+" automatic transmission fluid with the Chrysler MS-7176 specification. In line with the rapid technical development, the "ATF+" was quickly followed by the Chrysler MS-7176D and Chrysler MS-7176E specifications in 1993 and 1997, which were introduced as "ATF+2" and "ATF+3" automatic transmission oils. Significant for these two further developments of the original ATF+ was the improvement of the shear stability of these oils, i.e. the minimization of viscosity loss with increasing thermal load.
SAE Technical Paper 982674 gives the following shear losses from a 20-hour KRL shear test:
Chrysler MS-7176D ATF+2: 32%
Chrysler MS-7176E ATF+3: 14%
For immediate comparison, the test also cites results on the comparable GM Dexron III and Ford Mercon V specifications:
GM Dexron III: 40%
Ford Mercon V: 19%
The immense improvement in shear stability from ATF+2 to ATF+3 can be attributed to the use of the then new Group II base oil (for more details on the various base oil classes, see our blog article on automatic transmission oil), as well as the shear-stable viscosity index improver (VI improver for short) developed by Lubrizol.
Once again, an improvement was achieved by the ATF+4 oil with the Chrysler MS-9602 specification, which was factory-filled in automatic transmissions from 1998 onwards. By using a Texaco Group III base oil and another improved viscosity index improver from Lubrizol Corporation, the
ATF+4 automatic transmission oil has a shear loss of only 10%.
In addition to the renewed improvement in shear stability, the focus in the development of the ATF+4 fluid was also on improving the ATF+3 automatic transmission fluid in terms of its longevity. In particular, the anti-shudder test cited in SAE Technical Paper 982674, which examines the behavior of an automatic transmission fluid as a function of mileage in terms of its potential to cause judder during transmission operation, shows significant improvements here: While an ATF+3 automatic transmission oil shows noticeable transmission judder after a mileage of 30,000 miles, an ATF+4 oil reaches the same value only after a mileage of 100,000 miles.
