Melifluonze
Hey, thanks for the super discussion!
I went a little crazy, so now I have the following hanging around to have fun with over the next decade...
1978 400, unsure of heads, super clean, 20k miles... coult really just use this...
1978 440 - truck, 452 heads
1967 383 (2bbl, seized, in my '67 charger parts car), 516 heads
1967 383, 906 heads
1972 318 (seized from being left out by the previous owner)
Sooo, I've been reading and digesting the great info here. I'll be doing the assembly work and I've got a good machine shop down the road. The goal here is purely a fun cruiser, with solid power, nice sound, and driveability. No track, racing, etc.
I'm thinking about taking apart the '72 318 and bringing the block over to have it checked out. If it's good, I'm thinking I'll stroke it out to 390+ with 360 heads (looking for which ones to use for low compression, larger valves... I think it's 587 casting from 73-74) dish pistons to keep compression down, and a whiplash cam. If there's enough meat, I'm game for doing the 4" cylinder bores with a 4" stroke to make finding the pistons easier (360 pistons). Not sure about what intake yet. I'm sure there's something I'm missing, and I know 4" bores might not happen... but reach for the stars. I read that it is definitely possible.
That'll give me a 390+ with good power with the stock drivetrain down to the motor mounts, for cruising around, and a super sweet idle... and it'll drop right in without any changes... It'll be unhappy with the exhaust manifolds, but I can get to that after it's run in a bit, if I want to.
I think the engine will be the fun part, rather than fussing with transplanting a big block. I'll work the big block for my '67 charger (which currently has a 2bbl 383 in it) as a future project.
What do you think?
1967 383, 906 heads
What do you think?
