Does anyone know the NPT of that "extra hole/second hole" that we're talking about...the one circled in the pic above? I'm wanting to install a temp gauge sensor there...but it looks quite small.
[EDIT: It's 1/8th NPT, same as the oil sender fitting, which makes it useless for all the typical gage sensor bulbs that need to screw into a much larger hole.]
So I'm going look into making a tee that goes in the larger hole on top and can accept the OEM sender on one end and a gage sensor bulb on the other, but I doubt there's enough real estate in that tight, busy area.
