carguy300
Ok, let me know when you can. Thanks.
Yes, very strange it doesn't have the proper pedals.Those are not the elusive C-body pedals. Looks like someone retrofited an A-body set in the car. Worth pulling regardless, especially if its the HD setup with roller bearing pedal pivots from a 340/383 car and not the cheap plastic bushing style that came on /6-318s.
I hope to go to the junkyard friday 10/ 28 I will check on those partsI'm interested in the fender mounted turn signals with the wiring, thanks.
no luck on the formal search, But I will look a bit more@challenger340 if you happen to stumble onto some formals ('74-'78) in that yard I'd be interested in some parts of those.
Those are definitely NOT C-body pedals, the dogleg in the clutch pedal is the big clue.More people here have more knowledge than I on the subject, so I do NOT KNOW if pedals are original to the car. I have not removed the pedals, as I am not sure I can?
This car in the junkyard has 1 fender skirt laying in the trunk, could this be a factory skirt? Would the wheel opening moldings be worth getting? I pulled the front fender mounted "turn signals" but they have no lens and no bulbs? Are those factory, or an option? thanks for the info?Those are definitely NOT C-body pedals, the dogleg in the clutch pedal is the big clue.
As somebody mentioned - they are worth pulling, though - clutch pedals will always be a seller for you.
