1968 Plymouth Sport Fury fasttop 383 commando w/factory 4 speed (currently has 440)
Mine is an early '68 Inland car with no reverse light... kinda wish I had one.
That is definitely different Commando1 still cool. Also as an update, as i learn more about mopars the block in the car is a non hp block but is a 69' and the 383 in which i thought was the matching block is a C code non hp for 67' i guess which kind of ticks me off. Anyhow anyone know if they put some 67 blocks in 68's?
I HAVE to say this every time!!
I did NOT put on those fugly scoops, wheels, and emblems.
It looked bone effen stock.
This car breaks my heart every time I see it the way it looks now.
Then:
Not having a reverse light makes you a better attentive driver all around.
With no light you are EXTRA attentive when you want Reverse and not first.
Gotta be thinking all the time. Not having a light makes you absolutely sure you don't go to first initially. You make extra sure which is what you have to do with all your shifting, hence driving. That's why I am a 4 speed maniac.
It's a trucker thingie.
Hold it in second at 1900 RPM between that last turn and your immediate next turn, downshift with a slide and a click while making the turn, accelerate to the correct rpm, slide click into second. No lights.
If I get this straight a reverse light is an indicator inside the car not the outside backup light.
Completely unknown in Europe.
Under the dash
It lets you know if you accidently put it into Reverse instead of first when you are at a red light and saves you a lot of humiliation.
A real man puts it in gear and tests it before the light turns green :D
I never used the reverse light for anything. I knew by feel what I was doing. I just think it's cool to have the light in the era cars I'm talking about because that means I have the 4 speed instead of an automatic and I like seeing it on the dash.
The second part your are talking about a shift light obviously. Never had one of those.
Don't need no stinkin shift lights....
Just another Penile Enhancer.
"Look at me. I pretend I go drag racing".
If one does not know where reverse is they should just stick to driving an automatic !!!! :3gears:
