RDHOG
I am trying to figure out how to get my new Cragar SS wheels to fit the front of my 1969 Chrysler 300 with drum brakes. Has anyone add a 1 in spacer to get wheels to fit or can I get new drums?
Hey RD, how did your wheel spacers work out?They are the original drums and the Cragar rims would not sit flat because of the shape of the drum. So I just got these 1 inch spacers they seem like it will work.
Perfectly fine so farHey RD, how did your wheel spacers work out?
Nice! What size spacer did you go with and who manufactures it?Perfectly fine so far
Thanks for the info. I used US Wheel Adapter that are also for a Jeep except 1 1/2 spacer.Orion Motor Tech 5x4.5 Wheel Spacers, 1 Inch Spacers with 1/2-20 Studs Compatible with Jeep Wrangler TJ YJ Grand Cherokee Ford Explorer Mustang Ranger, 82.5mm Center Bore Wheel Spacer Kit Set of 2 https://a.co/d/0ZrX3RP
Glad it's working for you.
One would anticipate possible balancing problems when going from a factory steel hub centric wheel to a non-hub centric adaptor and then to a non-hub centric unilug wheel.
The available new 69 front drums would be an option if you're not thrilled with the adaptors. That's if you don't mind divorcing the drum from the hub. Got to be done sooner
depending on the width and backspacing of the rim compared to the original one ....
That's what I figure. Wider and more backspace puts me in the same place as without the spacer and original wheel.depending on the width and backspacing of the rim compared to the original one ....
