1969 polara trunk emblem
polarnj
NJ
My "Dodge" trunk emblem is broken in half, I was wondering if it's the same as the one for the Dart and Coronet, which are available new. They look almost exactly the same
This would be easy to determine in the Chrysler factory parts manual. The page format is each to read, parts group and description in the lh column, part numbers in the rh column, and the various models listed across the top of the page, with the quantities used per vehicle under them. If one part is used on different platforms, easy to see it in that format.
Download the manual at www.mymopar.com . Illustrations of the exterior trim and badging in the rear sections.
Sometimes, things that look very similar are not, being shorter or longer, depending on several factors, by observation. Even if they might be considered "the same".
There are two that look EXACTLY the same, the only difference is the pins. The Polara uses the one with the smaller pins
This is the one I got for my 69 Polara and it is PERFECT
NEW 1969 Dodge Dart Hood Emblem | eBay
Alan
If the emblem is on the car the clips are under it.
The clip is like a tiny sleeve that goes in the hole first then you press the emblem into them.
The original ones were maybe 3/16" long.
If you pulled the emblem then they are either on the emblem or in the hole.
Alan
