WANTED 1970 plymouth fury 111 conv
HI Sam, I am pretty sure I have one in good condition, let me check and get back to you, cheers.
I did forget, then I remembered, here is a pic of the fender trims i have. Needs polishing and the rubber strip glued back on at one end, but apart from that there are no dents or tears in the aluminum. I would like $30 plus shipping for the drivers side. (top one in the pic)
If you have paypal, that's the easiest way, I can fine a piece of plastic pipe to slip them in so they are protected and then can get a shipping cost to you if you give me your zip code. On a side note, I also have the rear quarter and door trim pieces as well. They fit a coupe/convertible.
I will pull them out and check the condition of all pieces first then let you know. i will also post pics again.
Here are the pics of all the trim, 6 pieces. All of them are same condition, no kinks, no dents, cracks or splits but need polishing. The rear quarter ones are 6 feet long. There is one with a missing rubber strip but I should have that here somewhere. I will check tomorrow. I will let the lot go for $150 plus shipping. I would put them all in a PVC pipe to do that.
Okay sounds good, I will PM you a total cost after buying a pipe and getting a shipping quote. I will need your zip code for that. Thanks.
