commando1
Critter, how many miles have you put on this beauty?
Probably both not enough and too many.Critter, how many miles have you put on this beauty?
When I took it for a drive last month it had 1100 I believe. Derek is definitely spending more time behind the wheel which is great to see. We were trying to diagnose a vibration as the car gains speed over 40mph. It gets quite bad the faster you go so thinking wheels/tires or possible rear diff as it does have some diff howl.
You need to check the rear diff pinion angle. Rear diff and trans tailshaft MUST be parallel. There are wedges you can buy to help "clock" the rear.
Check tires for shifted belts (not uncommon).
Well, get it checked asap, as you'll wear out the tailshaft bushing and bearing plus the U joints in short order.
Does the vibration pulsate? Or is it constant? Pulsating vibration is a number 1 marker for pinion angle. Constant vibration is more tires, U joints, bent shaft etc.
From the innerweb:
"The pinion angle is simply the angle between the rear end’s pinion shaft and a true horizontal line. The transmission angle is the angle between the transmission’s tail shaft and a true horizontal line.
Together, these angles form the driveline’s phase angle. Pinion angles can make the difference between a smooth ride, or a noisy and vibrating ride. Correct pinion angles are also very important to the life of your u-joints. Yes a driveline will work with 0* degree pinion angle, but the u-joints need a slight angle for proper lubrication. Without the correct angles, the needle bearings in the u-joint caps do not rotate. Those needle bearings need to rotate in order for the u-joint to operate reliably and smoothly. These u-joint angles should always be at least 1-degree to avoid wearing out the yoke bearings."
Simple angle gauge:
Then the question that begs to be answered is " how does that angle get out of whack"?
The transmission and engine are set by the mounts. The gear housing is set by the rear tube and springs.
What am I missing?
Sometimes there is a plate on top of the mount. The pinion angle should be set at perches and should be evident if someone ever moved them.Then the question that begs to be answered is " how does that angle get out of whack"?
What am I missing?
Sounds like a quick fix.in looking at rear tires see no weights so next weeks project will consist of removeing & checking rear tires for balance
The drive like is built so trans is to one side and pinion is to the other so even when full bottomed out to flying through the air you will always have u joint angles. Trans points down and rearend should point down at ride height so the chance of those angles lining up are slim.
Unless the parts have been changed I will agree. How does it get wrong?
Most vibrations go toward something loose or worn, and of course the tires which suck. 150 years of pneumatic tires and they are hardly better than the first ones. The wear out too fast, not enough tread and are truly impossible to balance in all conditions.
