commando1
Maybe the battery is beyond being able to take a charge.
Do you mean a faulty battery?Maybe the battery is beyond being able to take a charge.
Well it starts the car perfectly fine, it's still strong.
Well then.... Never mind.Well it starts the car perfectly fine, it's still strong.
Here's how you check what's wrong...Okay so the car isn't charging but i still have all electrics, so it cant be the ammeter, i was reading this link to determine the gremlin. Underhood Ammeter Bypass
I pulled the new alternator and put the original back in, no dice, I also pulled the regulator and swapped it out, still no charge. Okay so I'm going to run the alternator up to Advance Auto and get them to check it for me, probably buy a new regulator too.
Blah.
I will do this and I will see what happens, I have a suspicion it is not the alternator so I ordered a new VR, cant hurt to put a new one in. I will let everyone know what happens.Here's how you check what's wrong...
You'll need to make a jumper wire. One end will have a spade terminal that can attach to one of the field connections on the alternator. The other end is optional. The idea is to attach it to a good ground connection. I like using an alligator clip.
Unplug the green wire from the field connection. Leave everything else attached. Clip your jumper wire to the field connection on the alternator and the other end to a good ground.
Attach a voltmeter to the battery and check the voltage. It should be a little over 12 volts.
Start the car and immediately turn the headlights on.
Check the voltage at the battery. It should be at least 14 volts. Most likely it will be over that if the alternator is working right. If it is, the voltage regulator (or the wiring to the VR) is bad. If it's still at 12 volts, or less than 14 volts, the alternator is bad.
Do not run the car for an extended period like this as it can damage the battery.
What we've done here is duplicate the FSM procedure, except we aren't using a carbon pile to create a load of the system. We are using the lights instead.
Okay, so I found some time to do the test tonight, the battery measured at 12.4 volts with the ignition off. Then I pulled the green ground wire and put another wire on the ground terminal and earthed that wire, started the car and measured the battery, 16.1 volts, so yes it is charging. The alternator is good. Then I grabbed the green wire to push it back on the alternator and it came off in my hand, hmm. I had to cut some of the insulation to expose the original wire in the harness only to find it had been spliced to a yellow wire. Oh boy, so I am going to have to trace that wire and see where it goes. More updates to follow.I will do this and I will see what happens, I have a suspicion it is not the alternator so I ordered a new VR, cant hurt to put a new one in. I will let everyone know what happens.
As soon as the border opens, it's time for a road trip.Nice car and the perfect driver too bad shipping would kill me.
Cross the border in the middle of the night with your headlights off, pretend it's a moonshine run.As soon as the border opens, it's time for a road trip.
The problem for him wouldn't be crossing back to go home, so the lights can stay on. It's getting down to you that's the hiccup.Cross the border in the middle of the night with your headlights off, pretend it's a moonshine run.
I won't tell on you.Lots of Americans getting busted in Banff and Jasper parks on vacation using the "I'm going to Alaska" loop hole. Can I tell them I'm going to Mexico?
You can fly to the US without issues. Fly down, drive home. You will only need to self-isolate for 14 days when you get back.Lots of Americans getting busted in Banff and Jasper parks on vacation using the "I'm going to Alaska" loop hole. Can I tell them I'm going to Mexico?
