1970FuryConv
Hayden 2747 HD fan clutch: received face down in the box, with arrows on the side of the box pointing up. At least for this manufacturer, it’s okay to ship the fan clutch facing down. No leakage was evident.
Fan clutch install: new bolts and lock washers came with the fan clutch. I placed the fan clutch face down on my workbench, and placed the fan on it. Install the 4 bolts and lock washers per instructions at 15 – 18 foot-pounds, ½ short socket, 10 inch extension, 3/8 torque wrench.
A sleeve comes with the 2747 fan clutch.
Because the pilot on the Mopar water pump hub is 5/8 inch and the opening for the pilot at the back of the fan clutch is ¾ inch, this sleeve has to be installed in the back of the fan clutch for it to center properly on the pilot of the water pump.
Test fit
I used a block of wood and a rubber mallet to tap the sleeve into the back of the fan clutch, narrowing the pilot area to give a snug & centered fit on the 5/8 inch water pump pilot.
After installing the fan clutch, I placed assembly on top of the cabinet and leaned it against the wall so that the front of the fan clutch was vertical. The only acceptable storage positions are front down and vertical!
Fan install: Stayed vertical
Belts installed
Test fit
Belts installed
