SOLD 1973 Plymouth Fury Gold Sticker Special
The_Eagles’_Nest
Gurnee, IL
I’m putting my 1973 Plymouth Fury Gold Sticker Special up for sale. It’s an unrestored car with a partial repaint. It is in the common Chestnut Metallic paint with a fresh vinyl top.
Power is a 360 small block that has never been apart. Has new valve cover gaskets, PCV valve and the breather cleaned and oiled. Fresh tune up with NOS Champion spark plugs, NOS cap and rotor and new Mopar orange wires. NOS muffler and tailpipe with NOS exhaust hangers. Rear main is leaking but will be repaired.
TorqueFlite shifts excellently and is leak-free. No slip in the u-joints and power makes it to the ground with a 2.71 8 1/4” axle. Fresh 80W90 lube and over gasket.
KYB shocks all around, new tie rod ends, new lower ball joints, new bump stops, new front and rear brakes. New radiator hoses and Corbin clamps. Has Holley Retrobright headlamps. New Firestone Destination LE3 P225/75R15 tires.
New alternator, new voltage regulator, new ICU, original alternator and carburetor will be included.
The car still needs work, vinyl top install is not the greatest and the front and back glass need a reseal. A/C compressor is locked up, the temperature cable will need to be replaced. Y-pipe is blown out. Headlamp-on buzzer quit working, and the fuel gauge is not 100% accurate.
$8,500 OBO Gurnee, IL 60031
What is at the bottom of the rear door? Good luck with the sale of PH43K3D248325
Hi, can you show photos of the undercarriage, engine bay, trunk and the usual places for rust
Thank you.
Thank you.
