68PK21 440.6bbl
From the article:
"every square inch of it inside and out would be cleaned with so many Q-Tips"
"Q-Tips" Really? Amateur... needs to be dissembled and washed very carefully, if you don't the mold/fungus will come back. A/C unit needs to be dissembled and cleaned too.
Carpets & seats need to be professionally steam cleaned, a proficient carpet cleaner can do this. The headliner may be a problem. Basically you need to do a mold remediation.
"there’s room to get it in shape again and not lose your shirt"
Good luck on that one.
"doesn’t mind getting 12 mpg" False, you can get 20/22mpg with the 2bbl version if you pump up the tires hard and use the cruise control and that's at 80/85 mph. I got that with my 1976 Gran Fury.
At the end of the article when you click on the "MORE: PLYMOUTH FURY" link you will see a whole bunch of 'Never Sells'.
