commando1
That is just too weird.
'76 was the last year for the platform shared with Lincoln Marks. Typical Ford vacuum lines everywhere! That emerald green acrylic enamel will shine up like new, with some buffer action.
They indeed did have vacuum lines everywhere, and so did Chrysler. Say what you will, but Ford's still ran better back in those dismal emission controls days than did the lean burn junk that Chysler pushed out the door. I drove them all as part of my job then. GM made the rest seem like toads - they knew what they were doing. But then, GM helped develop the catalytic converter while Chrysler and Ford didnt' have a clue as to what they could do in those years.
I'm sure you know the intent of Lean Burn "junk" was to do without the cats GM was using. And it's not as if those early, restrictive and expensive cats were without issues. Rotten Egg smell anyone?
In the end, that LB system was compromised... but it's the same principle we use today, albeit with much faster computers and far more reliable sensors.
the proponent of Lean Burn at Chrysler was an idealist (Gorden Fenn),
Yeah, that's another way of saying intent. And the road to hell might be paved with good ones. I didn't claim it was successful. But it's not indifferent, which is how "the lean burn junk that Chysler pushed out the door" sounds.
And when I said "the same principle we use today", I wasn't speaking of AF ratios less than stoichiometric. I was speaking of looking at sensor outputs to control fuel and spark curves electronically. That was what made LB a new technology. It became "electronic spark control" by 1980 and worked pretty well from then until its final use in 1989 M-bodies.
Electonic spark control was on some 1972 Chrysler models.
Is that an oil filter on the air cleaner? I've never seen an air cleaner setup like that on any Ford. Very weird.
No....see red arrow in photo.
Thanks, and my mistake... I have to admit, I thought it was a bright idea for a replaceable part... but I also don't think I've worked on a car with one since the 80's.This car isn't worth much of anything. Of all the different Thunderbird generations this sixth generation was the worst selling of the bunch. Believe it or not the seventh generation, 1977-79, sold way better before dropping off the charts for the eight generation of 1980-82. I'm a Ford guy and I wouldn't pay more than $2000 for that car and I maybe generous. This is just one of those rare cars where "rare" doesn't mean good nor collectibel. This car is right around Ford's near collapse in the car market precisely because of these out of step brougham cars.
Oh, and that picture is of the Ford oil breather used from 1971-79. The other is as pointed out a vacuum canister. PCV is on the passenger side valve cover like always back then.
You and I both know that system is nothing more than a transistor-amplified on/off switch. All timing function is mechanical. No sensor inputs. No algorithmic lines of code. Not the same thing.
And I think you're now getting into the relm of exaggeration. There are people on this board still running with LB systems. A friend bought a time-capsule '77 Cordoba with a 400 LB a couple years ago. He insisted I take a turn at the wheel just to see how nice it drove.
It worked better on a drafting board than in the field, agreed. So did variable-venturi Motorcraft carbs, Diesel 350s, CVCC cylinder heads and a host of other mandated tech from the era. No one's hands were clean.
IDK if it's wrong for me to enjoy watching you guys debate automotive history. But heck, thanks for the read. You guys are two of my favorites and while I always hope the frustration won't turn ugly, the threads can be informative, nostalgic and a good read all at once.I was there, and heard a great deal about these LB cars from the field - no one was happy with them. But you can rewrite history if you like. If you have driven a LB 400 that drove great, chances are it was "retuned" by someone with some good sense. If you want to design a car to run well starving for fuel all the time, have at it. It is/was stupid. It wasn't the electronics that failed - they just couldn't respond well enough to keep the car running on a fine lean line. Kind of like trying to make a diesel passenger car pass emissions without cheating or being affordable with all the rube goldberg emissions crap under the car. What a mess.
Say what you want about catalysts, but they have stood the test of time and perform extremely well. Running at stoichiometric. Great driveability, fuel economy and performance, and low emissions. GM had it right from the beginning. Let the engine run like it should and let the emission controls clean up the pollutants.
