Good morning fellas! Got two bigger problems with my wiring that got totally screwed up by previous owner (wrong cable colors or the colors change and are connected with wrong cables, connections gone, list goes on)
1: car doesn’t start by key turn : the car starts by bridging the starter relay with a screwdriver . new starter relay and cables checked . Yellow signal cable that comes from ign switch works. I turn the key and 0,7 volts show up . Should be enough to activate the relay. BUT how do I measure the cable that comes from the transmission (yellow black)? I guess there’s no signal that tells trans is in park or neutral so that the relay doesn’t get activated. Because all other 3/4 connections if the relay work . Where is the ignition ballast located?
Any advices ?
2: Battery doesn’t load: new alternator installed. One green one blue cable go to the fld connections (does it matter on what fld what cable goes ?) the big battery connection connects with the same cable that goes from the battery to the starter ( doesn’t look right, self made stuff ) . One black cable not connected that comes from the plug where the blue one connects too and the wiring plan says it needs to go to the distr solenoid but I can find the place where it should connect ?!
Any help appreciated . Sry but it’s all messed up like s...t....
Any advices ?
