I see. I did not know that there was a small and large WCFB. So your intake will fit (without an adapter) a late WCFB or early AFB, before they moved the centerlines. I would not use the thicker gasket method. I would use the adapter to give a smooth transition. I do see where you were coming from, and by me saying "bolt pattern" muddied up the water. My adapter for that setup is only about a half inch thick.
