350hp.![]()
Where did you find these 55 extra HP from your first guess?
350hp.![]()
also, stock, the heads gave it 9.2:1 so, its gotta be higher, but how much is the question....
From this:Where did you find these 55 extra HP from your first guess?
Sounds like BGarf is a really good and sincere young man.This is my first time building an engine and I'm only a teenager. Every dollar going in, is one I've earned. ALL advice is much appreciated.
From this:
Hi, guys.
I have a 66 383 2bbl motor that i have shaved heads for to get to 10:1 compression, a single plane weiand Team G intake, Holley 4150 650cfm that has been choke honed to 730cfm, a set of 1 5/8" long tube headers, and a hyd flat tappet cam with 0.507 int./0.510 exh. 284 int./296 exh. 2300-6500. Any predictions on what kind of power i will have? It has the gold box for electronic ignition.
Thanks
Doesn't look like a very good combination to me. You have much cam for your engine displacement if you plan on running it in a street driven C-body. Unless you plan on building your 383 into a 496 stroker I would stay away from the Comp XE 284H and maybee go with the Comp XE268H. I would also ditch the single plane intake and go with the Edelbrock Performer RPM intake.You also need the proper valve springs to go with whatever cam you are using so that you do not float a valve while getting on the throttle. If you milled your heads for more compression I would do a clay test especially if you're running a high lift cam with stock pistons without valve reliefs. Milling your heads will add extra preload on your lifters so I would suggest getting some adjustable rockers or a set of custom pushrods to compensate for the difference. As for horse power gains Increasing compression , changing your intake and cam aren't going to be all that massive. I would estimate maybe a 50 or 60 hp gain at best. If you want to make serious power porting your existing heads or going with a set of aftermarket aluminum heads is the way to go.Hi, guys.
Thanks
The only way you will achieve those numbers is with some cylinder head porting or a good set of aftermarket aluminum heads. Performer RPMs are an excellent choice and they come with a variety of combustion chamber volumes and open or close chamber designs. They are a little bit pricey compared to some of the other heads out there such as the 440 Source Stealth heads or the Sidewinder heads but are of much better quality.I'm REALLY hoping for 400 horse and similar torque
